Is there a way to programmatically get a 2D polyline's Vertex X, and Vertex Y using Diesel? These coordinates may be found in the properties palette while a polyline is selected. I'm trying to write a macro that saves a user's polyline selection point, via the Lastpoint system variable, then programmaticaly gets the X, & Y vertex of that polyline.
Alternately the LIST command contains these points, but how may I save the LIST command results in a variable, then parse them for the last x, y, and save them in a variable. Reading the coordinates and typing them is not an option.
Please note: AutoCAD LT 2012 can't use LISP.
Solved by pendean. Go to Solution.
