Hi
Facing random crashes within AutoCAD LT 2012 after a few months of issue free use.
Originally had issues due to graphics options (had to use Autodesk certified graphics drivers, and also disable windows Aero in Windows 7)
PC is an HP Pro 3300SFF with 4GB RAM and using Intel HD 3000 graphics, Windows 7 Professional, 64bit.
2 recent errors:
AutoCAD LT Error Aborting
FATAL ERROR: Unhandled Access Violation Reading 0x0029 Exception at 3fe4702h
INTERNAL ERROR: !dbobji.cpp@388
If anyone can assist with this, much appreciated. There does not seem to be a facility to directly log a support call with Autodesk unless we hold a subscription, or am I just not looking in the right place?
Thanks all
Both of those are system type error messages: what changed on the system?
And how frequently do these happen?
Direct Support is Paid Support in this world these days, unless you are using software from someone trying to gain market share.
As far as we are aware, nothing has changed on the system.
Windows updates run, and I am careful to only use graphics drivers listed by Autodesk, so I disabled optional updates as this could change the drivers. No other significant changes to note?
Frequency, I am told it varies, but recently once per day, although it has been 3+ times in a day.
