AutoCAD LT Forum
AutoCad LT 2012 Constraints
2 REPLIES 2
primuscg
423 Views, 2 Replies
I use dynamic blocks but when I enter the Window Imperial block into my drawing and try to adjust the width and depth, i get an error message that says "one or more constraints cannot be resolved".   the other blocks insert and function properly.  What am i doing that has the constraint in the drawing?
2 REPLIES 2
pendean
in reply to: primuscg
Turn off constraints if you don't need them: DELCONSTRAINT command, usage explained in HELP.
primuscg
in reply to: pendean
Using the DELCONSTRAINT worked and the dynamic block works as expected.  thanks.
”Boost
