Hello Everyone,
I am currently using CAD LT 2011 and now i want to upgrade to LT2014 but i'm not sure my working files still can be used with lastest version of LT 2014 or not ? m looking for many technical resource but didn't found.
Appreciated any help....
Thanks.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Of course, you will be able to open 2011 DWG format in AutoCAD LT 2014 without any problems.
Maxim
4.2 Does AutoCAD LT 2014 software read and save drawings created by earlier versions?
AutoCAD LT 2014 reads drawing files from all previous versions of AutoCAD LT software.
(from attached pdf)
Maxim
Hi There,
Can any tell me where I can download AutoCad LT 2014 .
Regard,
Micheal
I have just upgraded from 2021LT to 2023LT ... and with "some" files I'm getting the error "could not confirm that this file was generated by a licensed autocad product".
I do use "blocks" from outside my company which might be the source of this error, but it is weird I'm getting the error only for some files (when all of them contain blocks not generated by myself).
