Unresolved reference files, and missing language errors ? Are 2 errors i seem to be getting alot while opening drawings.
It doesnt effect anyone elses autocad2011lt versions on other pcs, using same drawings ?
I seem to be getting these 2 errors alot of late, never got on them on 2007 ? My autocad locks up and i have to shut down using task manager...
Anyone got any idea why ?
Solved by pendean. Go to Solution.
Unresloved Xrefs usually means the paths are not saved the way your computer is set up to access them.
The second has a lot to do with not having the correct language packs installed for your LT version.
What's different about your setup than everyone else in the office? Who set them all up? Most likely the source for a fix as a first pass.
I have all needed language packs installed i believe ?
As for the Unresloved Xrefs i really wouldnt have a clue where to start
Open the EXTERNALREFERENCES palette, find the missing links, select them, then repath and save the full paths. Then SAVE your file. Now see if others in your office have issues with the file you did that with or not.
"Missing Language" error is just that: can't help you there.
Thanks, ive done that, but when i select drawing to fix my autocadlt 2011 locks up ?
