AutoCAD LT Forum
AutoCAD LT 2011 - Layer Control
5 REPLIES 5
mnewcombe
450 Views, 5 Replies
Is there a reason why the Layer control functions on the 2011 LT are so much slower than our old 2005 LT?  We tend to use a lot of layers and commands like 'select all' and 'select all but current' are very slow by comparison. How can I speed up the layer control functions?
5 REPLIES 5
Charles_Shade
in reply to: mnewcombe
Computer Specs?
LT 2005 was a much "lesser" hog of RAM and CPU power with repsect to LT 2011.
pendean
in reply to: Charles_Shade
... and I don't think LT2005 used Microsoft's .NET for the LAYER command (and in LT2011 it's a Palette that is always on and active, in LT2005 it was the older less capable pop-up).
Also, in LT2011, don't leave the Layer Palette open (it actively scans and updates on the fly, reason you can do so much with it while in an active command) and turn off SHOWLAYERUSAGE variable.
mnewcombe
Thanks for the info
mnewcombe
in reply to: pendean
Very useful advice thank you
mnewcombe
I will see if our IT guy can boost my ram. Thanks
”Boost
