I have a brand new Lenovo thinkpad T510, and should be more than capable to run this. It has been set up with windows Xp instead of windows 7(work network). It doesnt matter what command I use I can only get Maybe 30 seconds of use before the drawing screen freezes... I can still click all the other buttons, but however the drawing screen is frozen.. Could it be the windows 7 to XP switch? any other Ideas?
Are you using that Aero theme?
XP, or XP mode inside WIn7?
If the former, try turning off all background running apps and disconnect from the network and see if the problem persists.
This computer is running XP and not in compatibility mode. I've tried shutting down every other application and disconnecting from the network... however the problem persists.
