Please provide a link where i can download AutoCAD LT 2011 for Windows7/64-bit. Thank you.
Solved by nestly2. Go to Solution.
If your software is currently on subscription you can download 2011LT by signing into your subscription account and click on the download link on the left side of the page. If your software is not on subscription you will need to contact Autodesk or a Autodesk reseller in your area. You can contact Autodesk to request replacement media from the following link
Autodesk Media Request:
http://autodeskdocandmedia.com/
You can find a reseller in your area from this link.
http://usa.autodesk.com/adsk/servlet/ps/searchform?id=1088201&siteID=123112
I am trying to do the same. That is move a license of AutoCAD LT 2011 from an old computer(Windows XP) to a new computer(Windows 7 64bit). My problem is:
1. I do not have the original disk and cannot install the software on my new computer.
2. I have successfully exported the license (tried both public and private export options) and it does not show up in my autodesk account with an option to download the software.
I can still move my license back to the old computer but not to the new one?
I believe you should be able to download LT 2011 using the links in this similar topic. Once installed, I expect you'll be able to import your license. I would also suggest you copy the download to removable media and keep in safe location for future use if needed.
I have the same problème my computer was steal.
The likes do not works now could you give some new?
Best regards
Guillaume
