I am using AutoCAD LT 2010 on Windows 7 Professional 64 bit computer and when I try to save a drawing using the save as command, open a drawing using the open command, as opposed to using the windows explorer and clicking on the file, or when I try to export a PDF the program no longer responds and after waiting extended periods of time the program has still failed to respond prompting me to force close the program losing all of the work I have done. I just started a new job at a new company and up until now all I have done is open drawings to print them but this week when I started trying to modify drawings I am encountering this problem constantly and essentially cannot use the product. I have tried to repair AutoCAD, reinstall AutoCAD, and uninstall and install AutoCAD again and none of these fixes have worked. I have all of the service packs up to date so I do not know what the problem is.
The problem is that this is a small company so there is no real dedicated IT personal on staff.
As far as I know no one opened a file on a thumbdrive on this PC and nothing has been plugged into the computer to make it fail. I will try to use the PROCESSMONITOR freeware and try to decipher the results myself as well as post them on here.
At approximately 12:56 on the time code is when I used the open command to cause the error in AutoCAD. I was unable to really make any sense of the results of this so if anyone is able to make any sense of this and see a possible problem/solution that would be greatly appreciated. Thanks
