AutoCAD LT General Discussion
Member
claudbinns
Message 1 of 6 (606 Views)
AutoCAD LT 2010 fatal error crash when creating PDF from DWG
606 Views, 5 Replies
10-04-2012 08:25 AM
When creating a PDF from a DWG AutoCAD LT 2010 (runnning on windows 7) I get the following error.
unhandled access violation reading 0x6a162be0 exception at 6a162be0h
This only happens the second time I create a PDF - the first time it is very quick and there are no errors
I have tried a repair and a reinstall but am still having the same issue.
Many thanks for any help!
pendean
Message 2 of 6 (595 Views)
Re: AutoCAD LT 2010 fatal error crash when creating PDF from DWG
10-04-2012 01:28 PM in reply to: claudbinns
Do you have plotting set to background by chance?
Or do you have it set to open the PDF after creation?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
claudbinns
Message 3 of 6 (593 Views)
10-04-2012 01:53 PM in reply to: pendean
The PDF is set to open on creation - in Acrobat Pro. Should I try turning it off? if so can you let me know how? Not sure about the background plotting - where do check that - sorry to be such a novice. Many thanks.
pendean
Message 4 of 6 (591 Views)
10-04-2012 02:00 PM in reply to: claudbinns
Are you using the built-in PDF driver in LT2010 to create the PDF? Or Acrobat Pro?
Member
claudbinns
Message 5 of 6 (539 Views)
10-12-2012 06:44 AM in reply to: pendean
Hi there - sorry not to respond sooner. the printer used to create the PDFsis called DWG to PDF.pc3. Does that shed any light?
pendean
Message 6 of 6 (528 Views)
10-12-2012 12:45 PM in reply to: claudbinns
You can edit that PC3 file either directly on the PLOT pop-up, or through PLOTTERMANAGER command, and uncheck the "open after" box.
