My AutoCAD was working fine this morning then I took a break to work on something else and when I tried to Export to PDF the program froze and I got the not responding error and had to force close AutoCAD and now other simple operations are causing it to fatally freeze such as open, save as, etc.
Hello
Q1) Which Windows exactly ?
Q2) Have you the Automatic Windows Update ON ?
Q3) What do you mean by "Export to PDF" ?
For example is it plotting with the "DWG to PDF.pc3" driver ?
Q4) Have you tried to repair your ACAD LT 2010 ?
Patrice BRAUD
I will try that once I get it re-installed since using the export to pdf feature caused a whole slue of things to not work anymore I re-installed the program as I did yesterday afternoon.
