AutoCAD LT Forum
Autocad LT 2010 Crashes when opening File in Windows 7 Professional 64bit
2 REPLIES 2
1168 Views, 2 Replies
I installed Autocad LT 2010 Yesturday.  Installed with no issues.  I used the program all day opening and closing files.  I was very excited that I had a nice clean install.
Today, I lauched Autocad LT and tried to open a file.  The program freezes with no errors.  Windows trys to find a solution but just sits there forever.  I tried opening a file using multiple ways with the same result.  One exception, if I double click on the program I want to open using windows explorer it opens.
Same issue if I try to browse for a block.
I installed the service packs 1 & 2 but still have the issue.
Searched the knowledge base but can't find any answers.
Tags (1)
2 REPLIES 2
drjohn
Using Norton AV? Well known for causing these issues.  There is a fix at Norton if this is yur case.
Check this thread
HTH
Regards
DJ
in reply to: drjohn
That fixed it!
”Boost
