I installed Autocad LT 2010 Yesturday. Installed with no issues. I used the program all day opening and closing files. I was very excited that I had a nice clean install.
Today, I lauched Autocad LT and tried to open a file. The program freezes with no errors. Windows trys to find a solution but just sits there forever. I tried opening a file using multiple ways with the same result. One exception, if I double click on the program I want to open using windows explorer it opens.
Same issue if I try to browse for a block.
I installed the service packs 1 & 2 but still have the issue.
Searched the knowledge base but can't find any answers.
Using Norton AV? Well known for causing these issues. There is a fix at Norton if this is yur case.
HTH
Regards
DJ
