I have a problem with a drawing where I'm working with a certain number of blocks.
The other day Autocad crashed repetedlty when entering the block editor. I double-click on the block, the block definition dialogue box opens and the program freezes - I get the error message "Autocad LT has stopped running..."
I tried reopening the drawing, exploded the block and recreated it - problem solved.
Now this is happening again, except when try to explode and recreate the block using the BLOCK command, when the block definition dialogue box open - the program also freezes.
This only happens when I try to edit one particular block in the drawing.
Has anyone got a clue how to solve this or similiar issues?
Thanks.
Angelica
RECOVER the Drawing to Open it.
Delete the problem block and then PURGE the drawing
AUDIT and Fix all while the drawing is open
PURGE again
Close the Drawing
Open the Block drawing file if there is one.
AUDIT it while Open or RECOVER to Open it
Or recreate the Block in question
Or WBLOCK these entities to a new Drawing file and try it as a Block then.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
