Will AutoCAD LT 2008 work on Windows 7?
Potentially.
It should be installed using the XP Compatibility mode in Win7 Professional, Enterprise, or Ultimate.
Some have had good luck others not so much.
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Don't use XP mode, it's uber slow and painful to use. Instead just use the install 2007 on Windows 7 solution described here on the Longbow site
