AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT 2008 OLE insert problem
2 REPLIES 2
abaluyut
248 Views, 2 Replies
AutoCAD LT 2008 unable to insert PDF files. This function worked for about 2 years after software purchase.
2 REPLIES 2
pendean
in reply to: abaluyut
Wrong PDF format perhaps?
Do you get an error message?
Are all your layers thawed and turned on?
Did you zoom out or pan around to look for them?
Your post is light on useful details for others to help you remotely.
abaluyut
in reply to: pendean
Thanks, .Pdf insertion now works. Needs minor adjustment. After insertion of a pdf file in paper space, the inserted image becomes unstable when the dwg is zoomed in or out. it is like you always zoom in or out inside a viewport Even if inserted in model space, the same thing happens.
”Boost
