Seeking help on the below:
Got a drawing file that has 3 rooms namely room 1, 2 and 3. The rooms are arranged looking on a top view; from left is room 1, from right is room 2 and on top is room 3. Inside each room, I have entities/objects that I label H11001, H11002 and so forth for room 1, H12001, H12002 and so forth for room 2 and H13001, H13002 and so forth for room 3. The labels are define with attributes.
The problem is, I need to change the room number of the 2 rooms. The room on the left is now room 2 and the room on the right is now room 1. Room 3 is still on the top. The labels of the entities/objects in each room will be affected. Is there a way to change the labels globally for the 2 rooms only?
Any help will be appreciated since there's a lot of objects in each room.
Thank you.
Solved by pendean. Go to Solution.
Solved by drjohn. Go to Solution.
Solved by Kate_LT. Go to Solution.
Find & replace should work, although you'd have to run it 3 times. First to change H11 to some placeholder string of text, then to change H12 to H11, then to change your placeholder text to H12.
