Need help on how to create a template (text document) that I can use for attribute extraction for the below block.
Block Name: CE108A-07
Department Code IDARMI
Room Code DNSUI
Room Name line 1 IMAGING
Room Name line 2 ULTRASOUND
Room Number 1516A
Programmed Area 150
Actual Area 170
Floor and Base Finish
Any help will be appreciated.
Thank you.
bongs2009
Can't help much beyond this link as I do not do this often enough
The attached file is a simple one I use (Actually I had to look up this very information to remember how to use it).
ATTEXT - Procedures should be the same for LT 2008
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
tried to follow the procedure on the link ATTEXT but the message that i got after running ATTEXT is: **Invalid field specification: DEPARTMENT CODE C008000
below is the template that was used for extracting.
BL:NAME C009000
BL:X N007001
BL:Y N007001
BL:LAYER C020000
ROOM CODE C008000
ROOM NAME LINE 1 C015000
ROOM NAME LINE 2 C015000
ROOM NUMBER C009000
PROGRAMMED AREA C006000
ACTUAL AREA C006000
need help in figuring out what is on the above template.
any help will be appreciated.
thank you.
bongs2009
Underscore the Space at the name and see what happens.
And that is the name of your Attribute Tag is it not? If the Attribute Tag for Department Code is something else; say FUZZBUTT, then the name for that field needs to be FUZZBUTT C008000
Spaces are not allowed in Attribute Tags either.
DEPARTMENT_CODE C008000
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Charles,
thanks for the quick response
added underscore on every space on the character tags (see below) but still have an error message: **Invalid field specifications:
this time it did not specify which field has error.
BL:NAME C009000
BL:X N007001
BL:Y N007001
BL:LAYER C020000
ROOM_CODE C008000
ROOM_NAME_LINE_1 C015000
ROOM_NAME_LINE_2 C015000
ROOM_NUMBER C009000
PROGRAMMED_AREA C006000
ACTUAL_AREA C006000
And these are the Tag names of the Attributes for the data you are trying to extract:
DEPARTMENT_CODE
ROOM_CODE
ROOM_NAME_LINE_1
ROOM_NAME_LINE_2
ROOM_NUMBER
PROGRAMMED_AREA
ACTUAL_AREA
I hope I am not doing more damage than helping.
The ATTEXT link does have a warning under the radio button Procedures about not using the Tab key stroke but rather spaces when aligning columns. Possibly?
Did you leave a Return at the end of the Extraction file?
At this point the only thing that makes sense to me is that the Tag name and Field code for the extraction file are not the same.
How about posting the drawing so I can give it a shot?
And the Extraction file?
