The line weights from the .ctb file work in model space. I can make a pdf from it that prints property.
BUT
when I go to paper space and try to print, the xref'd drawings print with one line weight. The xref's are all imported on layer 0 and nothing on layer 0 is frozen or is turned off. I tried creating a new plot file and newly xref'ing the files but it did the same thing.
Up until recently, these files worked fine until I made some minor revisions and made new pdf's. It has effected two different drawings sets. I have not made any changes in the format, process or ctb file. I have not had a problem with this in the last 10 years. Why now?
Someone suggested there was an automatic update from Autodesk and the driver was changed.
Any ideas? I am sure out of them.
Thanks.
