I have installed LT 06 and it works fine as long as the user is an admin on the machine, when I switch the user to a power user it does not launch.
Is there any known solution to this problem? to have it run as a non admin?
Since 2006 Software is not designed for Win 7 I doubt that there are any solutions though generally when CAD is first launched as an Admin subsequent use can be through limited accounts.
You may want to post your query in this Forum:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
