AutoCAD LT Forum
Autocad LT 2006 on Windows 7 64 : need to launch autocad to open files
1 REPLY 1
301 Views, 1 Reply
I just intalled autocad LT 2006 on a windows 7 64 bits computer. The computer is on a network and i needed to modify the paths for autocad files in options ->locations (don't know if it's the good word in english, i have the french version). Before that Autocad only launch correctly on admin session and i needed to work with it on a user account, so i moved the files on c:\autocad and change a lot of paths (all pointing to the admin folders inaccessible with the simple user account) in the options.
Now, when i launch autocad i can open files, work on them and save them but if i don't launch autocad first and i try to open a autocad file from the folder it doesn't open i have 2 errors :
one error with explorer : "An error occurred while sending a command to the program"
and just after that another autocad error appear : "can not find the file specified drawing, make sure the file exists"
Can someone help me please ?
1 REPLY 1
pendean
LT2006 is not supported in Win7.
Look at Microsoft's website for tips on running old software in Win7 using Compatibility mode as an option.
Also ensure Windows Explorer is set to use ACLAUNCHER.EXE with DWG files.
”Boost
