3 out of every 4 times I select a hatch, to edit properties or delete, AutoCAD gives me the FATAL ERROR message and cannot continue. It is not just in one file, but in any file from what I can tell. Not just imported hatches either, AutoCAD standard hatches as well. I have reinstalled, downloaded whatever service pack I could find. This is so harmful to productivity. Please help!
Hello
Could you recover the DWG and use the recovered DWG ?
Have you always the same problem ?
You are running your ACAD LT 2006 + SP1 + PostPatch on which Windows exactly ?
Windows 32 or 64 bits ?
Bye, Pat
Patrice BRAUD
i HAVE THE SERVICE PACK BUT NOT SURE OF THE POST PATCH, I DON'T BELIEVE I SAW THAT ON THE PAGE OF SUPPORT ITEMS FOR AUTOCAD LT 2006.
I AM RUNNING WINDOWS XP 2002 SP 3, NOT SURE BUT I BELIEVE THAT IS 32 BIT.
YES I CAN RECOVER, THE FILE CONTAINS NO ERRORS BUT IT WILL CRASH AGAIN. NOT ALWAYS IMMEDIATELY BUT SELECTING THE HATCH WILLQUITE FREQUENTLY CAUSE THE FATAL ERROR.
THANK YOU VERY MUCH
Hello
Maybe you could consider to recreate hatches which generate the bug !
Bye, Pat
Patrice BRAUD
I also sometimes have the problem of AutoCAD shutting down completely and disappearing (this just happened). No warning, no error message, program force closes instantly. Upon reopening AutoCAD just tells me it did not shut down properly but will try to recover drawings. I get the last manually saved versions and sometimes AutoSave files.
Do you run Norton Products bey chance?
Run a Registry Cleaner recently?
Video card info?
Win XP SP3 with how much RAM?
Straight CAD Content? Is there any vertical content like Civil or Autodesk Architecture?
Big file, little file?
HPORIGIN near the area the Hatch is created?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
