I have a client with a winXP 32bit SP3 pc and autocad lt 2006 installed
In recent days, his AutoCAD lt 2006 keep crashing with this error:
AutoCAD LT Application has encountered a problem and needs to close. we are sorry for the inconvenience.
and the error signature as per attached.
i have tried to reinstall .net framework but nothing help.
anyone knows the root cause of this problem as it was fine on the past few month.
Hello
Have you completely Un-Install, Reboot, Re-Install ?
Have you installed the SP1 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5837317&linkID=9240818
Better idea : have you an other ACAD LT 2006 OK on a other PC ?
If YES : with a Local Admin count, try to copy / paster the DLL which causes the problem !?
Bye, Pat
Patrice BRAUD
The Restore may answer the "what changed on the OS?" question.
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
