I am trying to install AutoCAD LT 2005 on a system using Windows Vista. Are there any patches I can install to make this work? Thank you.
Where are you getting hung up in the install?
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If anything, you'll have the most problems with licensing as the architecture was not made for Vista. So even if you do get it working, the license service will still not likely run or work.
