There is a problem on my autocad LT 2005, file cannot plot. There an error message that goes like this.
"Fatal Error : UnHandled Access Violation reading 0X0000 Exception at 0h" and an error message at command prompt in autocad that reads "AcPlotGui.arx is an invalid ARX file" each time when want to plot, the error message box appear then when click "ok" autocad shut down. With much appreciation, kindly let me know how the error can be resolved.
There is a Service Pack available for LT 2005 that relates to this issue:
http://download.autodesk.com/ProdSupp/downloads/Readme_2005_SP1.htm
Have you recently re-installed the software and/or did this just start?
Updates and Service Packs:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240818#section7
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have install the Service Pack for AutoCAD LT 2005 before, but the problem still there.
Is there any solutions which i could try on it ?
Currently, i have yet to re-install the software...
Appreciate your advice.
THank you very much.
Wait for another poster to chime in before you go the re-install route if you can.
Printing and Plotting Forum can be found at:
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
which may have some other solutions for you.
