Are all the computers identical? Brand name or custom built? What
processor, RAM, etc? Which parts have you replaced. I've had obscure
problems that turned out to be power supply or motherboard. I've read
of similar problems resolved by changing the video card or the video
card drivers. Some times it's upgrading to the latest video card
drivers that helps, sometimes it's using an older driver. It could also
be a RAM problem or a mouse driver problem.
Martin
jonlamb wrote:
> Hello, I am have a problem with 1 of 4 PC's that we have that run LT2004
> It will work fine for a few days but then it will start to hang indefinately when opening. Once it starts hanging, the only way to clear the problem is to re-install and that fixes it for a little bit.
> To try and cure the problem, we have wiped the PC, then replaced it. We have deleted and re-created the user off the network several times in case its a profile issue. We have moved the PC onto a different network run with different patch cables / points at each end. It is running Windows XP and the server is running Windows 2003 SBS.
> The other workstations have no problems. It seems that we have replaced everything we can but the problem is still occuring just for this person.
> I'm dont use autocad myself, i'm a hardware / network guy but I can get any additional information of the cad users if needed.
> Thanks
> Jon
