i have problems with LT 2002 on Win 7 x64bit. It is not possible to open that file on Win 7 but the same DWG is working on Win XP Pro.
I read that there is a patch available. Is it right?
If you need more information pls let me know.
Regards
Sven
LT2002 is not supported in Win7 64bit. XP Pro is 32bit, if you had Win7 32bit it would appear to work for many with your old version of LT (still not supported by anyone).
Win7-64bit has an XP Compatibility mode for ancient software, which might or might not work for you. Explore it in your Win7's HELP or Microsoft's website.
Not Supported=no patches or fixes planned by anyone.
This is an FYI for anyone having problems with LT2002 in Windows 7 on a 64-Bit Computer
Windows 7 recently released an update that fixed my failure-to-install problem with Autocad LT 2002.
When I created a new file in the newly-installed LT2002 it worked fine, but the program crashed when I tried to open older files created from LT on another computer running Windows XP and transferred to the new operating environment. Trying to open Autocad with a preexisting file, I would receive a fatal error message along with the file-path leading to a *.dbx file before the software crashed.
I was able to get these files to open and use them by going to the *.dbx file location shown in the error message and creating a file folder with an easily identifiable name (Such as "Conflicting File") and relocating the file listed in the fatal error message to this location. I get a "proxy information" dialog when opening these old LT files but then, I've never worked on a version of Autocad where I don't get this message.
So, Autocad LT 2002 DOES work on Windows 7 on a 64-Bit Computer !
