AutoCAD LT Forum
AutoCAD LT 09 Attributible Blocks in AutoCAD LT 13 not working
2 REPLIES 2
514 Views, 2 Replies
I have my title blocks, detail titles, bugs and other attributable blocks set up in 2007 and am using them in 2009. When I double click on the block to open the dialogue box in vs 2013 I don't know what to do with the dialogue box that comes up. I am an average user and someone helped me set up these original attributable blocks, but I feel confident to modify them through 2009. But I don't know what to do with this dialogue box. I just want to be able to fill in the text I want in each field.
I've attached a pdf showing the two dialogue boxes I get, one with 2009 and one with 2013.
I think this probably has a simple answer. Much appreciation for any help with this.
Thank you.
2 REPLIES 2
pendean
2009 is the old classic editor (read the header on the pop-up).
2013 is using the new editor (read the header on the pop-up).
You can still use the old command by typing it or if you want by changing the double-click behavior to use the old command in CUI's double-click: the old command is ATTEDIT command, the new command is EATTEDIT command.
in reply to: pendean
Hey, thanks, Dean for the almost instant answer. That worked!!
”Boost
