Hi Dean, can you help. I have had LT 07 installed for three years now with no problem on Vista home Premium. I simplly installed it using compatablity XP mode. Just a day ago starting LT - it seemed to get caught up in a loop - tring to load a templete drawing ?? The previous session a couple days prior was no problem as usual. After 3-4 min I killed the task in Windows task Mng. Tried it again - same problem! Figured I would reboot the PC. After that attempting to start LT I simply get the "AutoCAd LT has stopped working" error. I have uninstalled the program and reinstalled it twice - once adding SP2. Any ideas please.
Cheers,
Vic
It may or may not help, but try the Autodesk recommended uninstall and reinstall procedures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
