As soon as I click the drop down the screen shows as blank and the program freezes. This happens with all the following commands, Save AS, Insert.
I have checked the FILEDIA and it is set to 1
I seem to have the problem with all autocad products on my Windows 8 pro desktop. I have tried Autocad LT 2013 & 2014.
I just tried that, doesn't seem to help. I pasted a picture of what happens whenever I try to perform any command that brings up the dropdown menu. The box is blank and the program freezes.
I am not logged into autodesk 360, we thought that might be part of the problem.
The files are located on our server, it remains frozen until I force the program to close with the task manager.
It's wierd, one day it works fine and then the next day it does this. It's very frustrating.
Check to see if you have a phone or something plugged in to the machine. I saw this same problem recently and that was the fix - unplugging the phone.
That reminds about reading the same thing about i-whatevers being a culprit.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes, unplug your iPhone or iPad. That should fix the problem.
I can confirm, I had the same issue.
Complete lock ups when tyrying to use drop down dialogue boxes..
It turns out there is some sort of software clash when my samsung phone is plugged into my pc.
Yeah, I had already tried it. And that was definitely the problem. Definitely an odd issue though. thanks for checking if it worked or not. I was just curious if there was a fix for it. But I tend to doubt it.
Oh, my, gosh. I have been WRESTLING with this for over a year. That was it. Unplug my phone and BOOM, my drop down works! AWESOME THANK YOU!
Thanks Guys!!! Unplugging my phone solved the problem. It's been driving me crazy!
