I'm trying to plot my drawings and have all my line weights be the same in the final plot so that no line is more bold than another. I do custom home designs and am now adding in additional information that uses different colors for appliances, plumbing, etc.
I'm using the standard red, cyan, magenta, green, 252 gray scale colors, however, when I plot, all of the lines except red are thick and make the objects entirely too bold for my purposes. How do I fix this other than changing everything to red? I didn't have this problem when I worked with AutoCAD 2006 at my old company (we had drafters set up this stuff for us), but now that I'm on my own and trying to get my own plotting figured out, I'm struggling.
I attached an example for reference. It's the windows (gray scaled), plumbing fixtures (cyan), and appliances (magenta) that come out entirely too dark.
Thanks for the help.
Solved by derekahoward. Go to Solution.
I just figured it out. The problem was in the plot style I was using. I had to go in and change the line weights in the plot style table and now it works how I want it to.
Add some weight and nuance to your drawing so that it makes a statement.
Anyone can produce monochrome drawings; and they look it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
