AutoCAD LT Forum
AUTOCAD 2010 LT PROBLEMS
8 REPLIES 8
Message 1 of 9
nursan1453
1015 Views, 8 Replies
Hi.
I'm using AUTOCAD 2010 LT .
My PC : HP Z200 workstation.
CPU: Intel(R) Xeon(R)        X3430  @ 2.40GHz  2.53GHz.
RAM: 6GB
Windows 7 Professional 64 bit
Graphics card : NVIDIA Quadro FX 580
When drawing line , circle , ellipse ... cursor moving very very slovly.
And program giving fattal error several times
8 REPLIES 8
Message 2 of 9
Bob_Zurunkle
in reply to: nursan1453
Search these forums for a treatise called Speed up AutoCAD. It sounds like it might be related to the graphics card or graphical settings within the program. Turn off the Aero theme and any dynamic and/or graphical gewgaws. also check to make sure SAVEFIDELITY is ste at zero (that's in case of long saves).
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 3 of 9
Charles_Shade
Try SCALELISTEDIT from the Command Line?
Anything odd in that list?
Many Layer Filters perhaps?
LA from the Command line
Message 4 of 9
pendean
Turn off Win7's AERO Theme and use it's alternate WINDOWS BASIC THEME.
And turn off DYNMODE in LT, see if that helps too.
Message 5 of 9
TomSalomone123
Hi, Sounds like this is an application error, but you could try the following and see if it helps:
1. Issue the 3Dconfig command
2. Click on Manual tune
3. Make sure “Hardware Acceleration” is selected
- Tom Salomone
HP Workstations Representative
Message 6 of 9
pendean
in reply to: TomSalomone123
There is no 3DCONFIG in LT2010... .
Message 7 of 9
chris.bronw39301
in reply to: pendean
Last night Windows 2010 pushed an update. Today every DWG has scattered lines all over the drawings. I have updated the graphics card driver to no avail. I also can't find any graphics acceleration to turn off.  What would turn off graphic acceleration for AutoCAD 2010 LT? 3DCONFIG is an invalid command for 2010LT.
Message 8 of 9
pendean
in reply to: chris.bronw39301
Windows 10 updates have never been documented doing that inside DWG files: are you sure these "scattered lines" are not hatch patterns that are too far away from your 0,0,0 location?
Or is the actual problem your very old LT2010 is not supported in WIndows10 (that means Autodesk will never help you fix a problem) https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
Tips here may help your old software https://www.longbowsoftware.com/Tips_and_Tricks.php
Message 9 of 9
Bob_Zurunkle
Hey wasn't there something gong on way back when that if you opened a certain drawing file it would make lines like that and then they'd move as they ate up your file? It had something to do with Captain Kirk or Star Trek or something. Sound familiar?
”Boost
