I am userin AutoCAD LT 2010 on a Windows XP computer with service pack 3. When we start autoCAD the ‘Initial Start’ pages shows but not fully and the it hangs( this worked ok until last week). If I go into the Task Manager it shows a process ‘AdMigrator.exe’ which is consuming 50% CPU if you ‘end’ the process then autoCAD start and works ok.
Can any tell me have to correct this please?
Windows XP has a restore feature, take it back to at least the week it all worked and see if the issue go away.
Found this in a search of the forums. Maybe it will help you. I found alot of instances that the admigrator was sucking proc and 98% of them resolved with a .NET framework fix.
http://forums.autodesk.com/t5/AutoCAD-LT/Cannot-Launch-AutoCAD-LT-2010/td-p/2462677
HTH
DJ
I have found .NET's to be a notorious problem with Window's updates and usually will Restore to resolve and remove the update.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
