AutoCAD LT Forum
AutoCad 2004 LT and Windows 7 compatibility
4 REPLIES 4
gock5
5596 Views, 4 Replies
Is Autocad 2004LT compatible on a Windows 7 platform. I know it's not "supported" by Autodesk, but...!
4 REPLIES 4
in reply to: gock5
Win7 Pro versions, have XP Mode options for running old software: may or may
not help: remember LT2004 is a 32bit program, not a 64bit.
Dean Saadallah
http://LTisACAD.blogspot.com
in reply to: gock5
Also explore this, cheap until the 15th:
http://www.amazon.com/Autodesk-057B1-05A001-P101A-AutoCAD-LT-2010/dp/B001UO8M8M/ref=sr_1_3?ie=UTF8&s=software&qid=1261752545&sr=1-3
Dean Saadallah
JessicaD42
in reply to: gock5
Gock5,
Dean is correct -- you can always run Autocad 204LT through XP Mode should your hardware permit. Also, there is a resource available at the Microsoft Windows 7 Compatibility Center to verify compatibility for hardware and software questions. For further information, please go to the following link: http://bit.ly/1gW6Ns
To learn more about XP mode and Virtual PC, please go here: http://bit.ly/lvAjC
Jessica
Microsoft Windows Client Team
Charles_Shade
in reply to: gock5
You should run this answer and maybe expand upon it a little in its own thread as there are usually a few here asking about older Autodesk software and newer MS OS.
Regards, Charles Shade
”Boost
