AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Auto CAD license combination
2 REPLIES 2
320 Views, 2 Replies
I have combined all the licenses of our company to one SN.
but all old SN still can be used.
is that normal?
2 REPLIES 2
pendean
You need to contact an Autodesk reseller to discuss licensing.
TravisNave
The system should eventually expire those old serial numbers and prevent them from being activated.  You should get an error stating that the license serial number is invalid.  Granted, this will not affect any previously installed and activated software using that serial number.  However, subsequent reinstalls should no longer work.  In any case, for licensing compliance, you should only use the number of licenses that you own.  If you have any questions, contact your Reseller as Dean advised.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
”Boost
