>Anyone know of a method to batch process attribute extraction from
>several hundred drawings? We are using Lt 2000 or Lt 97 on several
>different platforms.
Paul,
you can write a small script file which extracts the attributes from
the current drawing and quits. Then use the old DOS FOR command to
have AutoCAD run this script with every drawing.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Webmaster, AutoCAD Developers Group Europe, http://www.adge.org
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
