Hi All
I have a main drawing that I want to pull into another drawing as an XRef. When I try and attach the drawing as an attachment I get then message *Invalid* in the command line.
I have taken the drawings off the network and put them directly on my computer to make sure that it is not a network issue, but I still cannot attach the drawing.
Can someone help please?
sean
Are there any XREF's currenlty attached to the drawing you want to XREF?
Sometimes there can be a circular XREF causing the issue.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
