Trace means to manually draw over "something". You draw in autocad
using Line, Pline, Arc, Circle and more.
What kind of help exactly are you seeking: How to draw in autocad? Or
are you wnting to buy raster to vector software for conversion.
Also read this:
http://www.mapquest.com/features/main.adp?page=legal
"...You may not commercially exploit the Materials or the underlying
data, including without limitation, you may not create derivative
works of the Materials, use any data mining, robots, or similar data
gathering and extraction tools on the Materials, frame any portion of
the Materials, or reprint, copy, modify, translate, port, publish,
sublicense, assign, transfer, sell, or otherwise distribute the
Materials without the prior written consent of MapQuest. You shall not
derive or attempt to derive the source code or structure of all or any
portion of the Materials by reverse engineering, disassembly,
decompilation or any other means. You shall not use the Materials to
operate a service bureau or for any other use involving the processing
of data of others. You shall use the Materials and this website for
legal purposes only and shall not use them in any manner that violates
the laws of any jurisdiction. You do not receive any, and MapQuest and
its licensors retain all, ownership rights in the Materials. You may
not alter or remove any copyright notice or proprietary legend
contained in or on the Materials. Nothing contained herein shall be
construed as granting you a license under any copyright, trademark,
patent or other intellectual property right of MapQuest or any third
party, except for the right of use license expressly set forth
herein...."
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
