AutoCAD LT Forum
Area within block as an attribute
0 REPLIES 0
Message 1 of 1
Lukasz K
135 Views, 0 Replies
Here is the problem:
I'm detailing many shapes made of plates. I want to create a block with attributes as follows:
NO.
Name
Area
Then, I want to export it to csv file and import to MSExcell to make part list.
Area*thickness=volume
volume*density=mass of each element
Is it possible to put area of an object (i.e. polyline) as an attribute to a block?
I know that I can put FIELD in a block with attributes with "Area" property of an object. But only in full AutoCAD 2006 not in LT
When I check properties of an object there is Area property - Can I export it outside AutoCAD?
Thanks for any kind of help.
Lucas
0 REPLIES 0
”Boost
