Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Use PE command to convert the lines to a closed polyline, join them together: Input command PE and enter, then input M option, then select all objects and enter, press y, press J to join all of them. At last, input command AREA and select the closed polygon, check the area result in command line.
Also remember that tenant areas usually go to centers of demising walls with other tenants, and if memory serves they go to exterior walls but don't go to center of separations with Common Area Maintenance. Tenant areas plus CAM areas should add up to total building area, but I may be missing something...
