I have a brand new windows 7 computer with LT 2013. I had XP with LT 98. All my old files seem to have transferred over with one exception. My old architxt.shx font does not seem to be available to me. Even though it shows up graphically on my old drawing text, any new text becomes romans.shx. I even tried copying some existing text and that didn't work either. I have the font on a floppy disc but my new computer doesn't have a floppy drive. Is this font available?
One other problem. Hatching my old drawings is very slow. Works fine in new drawings.
Solved by Charles_Shade. Go to Solution.
Do you still have the old System? If so you can grab the font and move it to a Disc or Flash and then transfer it to the new LT 2013 Font Folder.
You can find that folder under OPTIONS, Fields tab, Support File Search Path.
Google if you can't. Find one that is close, likely the compatriot is not out there.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
