AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
APPCRASH , AutoCAD LT has stopped working
10 REPLIES 10
Message 1 of 11
dispensetech
4410 Views, 10 Replies
HELP!
-Get the following error when plotting or previewing in AutoCAD LT 2010, using Vista Ultimate, plotting to system printer HP 5100
-Only faults when selecting 11x17 paper sze, letter size plots normal
-Printer works fine with other apps
Problem Event Name: APPCRASH
Application Name: acadlt.exe
Application Version: 24.0.55.0
Application Timestamp: 499008e6
Fault Module Name: StackHash_90cf
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791adec
Exception Code: c0000374
Exception Offset: 00000000000a6e97
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 90cf
Additional Information 2: e9e40b45b3fa420ce97bf78fe7137a7f
Additional Information 3: c0fc
Additional Information 4: 13a1d1c64633765bd17ddf062cf01078
10 REPLIES 10
Message 2 of 11
in reply to: dispensetech
Did this problem just start?
using a system printer driver, or PC3 file?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 11
dispensetech
Yes, just started today. Started using AutoCAD LT 2010 on new computer about 1 week ago.
Same fault using system driver or .PC3 file
Message 4 of 11
Windows Restore, see what got installed overnight, go back to yesterday's
settings if needed.
Dean Saadallah
Message 5 of 11
dispensetech
No luck. Restored to yesterday's settings, also removed and re-installed AutoCAD.
I realized that this only happens when plotting to 11x17 paper, other programs print to 11x17 without any problem.
Message 6 of 11
dispensetech
FYI
Contacted AutoCAD tech support. Was told that this is a known problem with AutoCAD 2010, 64-bit Vista and HP 5100 series printers.
Printer works fine for every other application EXCEPT AutoCAD 2010. Does not work with AutoCAD TrueView either, same issue.
Was told to try and roll back my printer driver, did not help.
Was told that the only other work around was to print to PDF and then print 11x17 through Adobe. This works, but very time consuming.
Any other suggestions are MUCH appreciated.... Thanks...
Message 7 of 11
HP5100 is an old and great workhorse, I still have one and use it daily: but
I'm running 32bit OS here. Now I know what will happen if I go 64bit: thanks
for the heads up.
But why would it just stop working one day out of the blue: that makes no
sense.
Dean Saadallah
Message 8 of 11
Keamosaaby
My crash is with Revit 2011
Any Ideas why, this has been an on going problem when I try to modify any materials.
Problem signature:
Application Name: Revit.exe
Application Version: 2012.0.2011.309
Application Timestamp: 4d785e92
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.17514
Fault Module Timestamp: 4ce7c8f9
Exception Code: c0000005
Exception Offset: 0000000000028c28
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 8d2a
Additional Information 2: 8d2ac9ded0a2126640615ccbe07f9afb
Additional Information 3: cd21
Additional Information 4: cd21f83e2aa85fab0568643ae4a8f566
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Message 9 of 11
Charles_Shade
in reply to: Keamosaaby
Message 10 of 11
mtjeley
I have just installed my new 2012 autocad lt but it will not open
with the message a problem has caused autocad to stop working.
I have upgraded my graphic card Driver and I do not have a hp printer.
Locale ID: 1033
Message 11 of 11
pendean
in reply to: mtjeley
Installation Help from Autodesk:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=9240817
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=15892664&linkID=9240817
If you are on subscription, visit your Autodesk
Subscription Page for direct Autodesk Help:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2915212&linkID=9240817
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240817
Different options that are available for self-help
technical support from Autodesk Product Support
E-Services:
http://www.youtube.com/watch?v=Ylj0o-R_Zn0
”Boost
