AutoCAD LT 2012 is here! Check out the new features then try it free for 30 days (usa.autodesk.com/autocad-lt/trial). You can even run the trial online, no download required (depending on available bandwidth).
Some of my favorite features:
I'll be blogging in detail about these and other features in the coming weeks, but you can also read a good overview here, or watch the demo videos on YouTube (search for AutoCAD LT 2012).
The AutoCAD LT 2012 Preview Guide was a companion to the AutoCAD 2012 guide instead of a stand-alone doc. It was useful to our beta community but likely won't be published for general use.
Can I ask what you're looking for specifically that you're not finding on the website or in the demo videos?
@Charles_Shade wrote:
Google does not find a comparison such as this one released in 2010:
The web version of this year's comparison matrix is on the AutoCAD LT product center. We're working on a PDF verison which should be available soon.
Did they fix the severe performance issues seen in 2011LT with Aero? Or did they at least figure out why users with Win7Pro64 couldn't "Disable Visual Themes"?
Yes, the issues that some people saw with AutoCAD LT 2011 and Windows 7 have now been resolved. AutoCAD LT 2012 supports hardware acceleration, so it can take full advantage of the computer's graphics card. To check if your card is certified, go to www.autodesk.com/autocad-graphicscard. (There isn't a separate listing for LT, but you can use the AutoCAD database.)
No mention of LT2012 and Citrix:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
I don't expect to get anything. It's fairly typical for a company to release a product which is fualty and fails to meet usage requirments for many of its users. Most often, said company fixes the problems and makes you buy the new version to get what you were expecting from the orignial. Way of world, sure, but not exactly the kind of behavior that earns my repeated business.
I did start a thread a long time ago and it had lots of participation (even from one of AutoDesk's employees). I can understand that not everyone had my issue (though several others did) and I can also understand that some of the workarounds would be sufficient to satisfy some of these people. But for how I need to use AutoCAD to make effective use of my time, there was no adequate workaround.
If you want the long version, you can see here:
http://forums.autodesk.com/t5/AutoCAD-LT/Measurements-and-O-Snap-Ext-jerky-on-high-end-cert-GPU/td-p...
If you want a sumary of why the workarounds failed to satisfy me, see here:
http://forum.notebookreview.com/7289835-post9.html
I've had 4 different 8740w laptops in the past year (don't ask). The 1st 2 had ATi M7820, the other 2 had Nvidia FX5000M. Both are "certified", but I'm not sure why that matters if LT2011 doesn't use hardware acceleration. From the users I've received feedback from, the problem seemed related specifically to Win7Pro64. Other Win764 versions seemed fine for others, the Pro version seemed to be a common denominator among users with my problem. Of course this just a guess as I lack both the resources and technical knowledge to prove this to be true.
Interesting observation: since upgrading Windows 7 tend to take less than 10-minutes online (but parting with +/-US$100), it might be worth it for someone with big issues to discover if that is true.
My humble HP Pavilion DV6 with Win7 Pro doesn't seem to be affected by much with LT2011 when I am out of the office.
Hmmm, your HP Dv6 makes me think the $100 is not worth risking...you clearly demonstrate that the problem is not caused by, or least not 100% correlated with Win7P64.
I'm currently using LT2007, and a coworker is using LT2006. We're wanting to upgrade to LT2012. Is it possible to purchase an upgrade to LT2012, or must I purchase a full version of LT2012?
You would need a new Full seat for each user.
Upgrade not available for 5 and 6 year old software.
Look at Amazon from time to time and you may find a good deal for the LT 2012.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Can anybody tell me for certain if 2012 LT will allow insertion of image files (TIFF or JPG) into a DWG? I have a VERY old version of LT and it DOES NOT allow insertion of such image files. I am thinking of upgrading, and I need to know FOR SURE.
Thanks!
Robert Wichert
Download the Trial and test.
You can know first hand.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
A more direct answer = yes. It will insert jpg images at least. I have done that.
HTH
DJ
