I'm sure there is a setting to handle my issue, but I am just not sure which one.
I am running AutoCAD LT 2012 and am just getting started using Annotative Text, Dimensions, and Leaders. I have one large file with multiple details at multiple scales. If I annotate a detail at the 1" = 1' scale, and then switch to 3/4" = 1' scale to annotate a different detail, it changes the text 1" per text to 3/4" per in the model.
Somehow, even when it does this, it maintains the 1" scale and everything looks right in paperspace. Any setting to change so the scale for text, dimensions, leaders I have already created remains the same?
Solved by KateMorricalTowne. Go to Solution.
Perhaps it's the "automatically add annotation scales" that is confusing you?
http://ltunlimited.typepad.com/my_weblog/2012/07/automatically-add-annotation-scales.html
Perfect. Your post was exactly what I was looking for and works great. Thank you!
