My question has to do with the Annotation Tool Palette out-of-the-box. For a given scale, the Callout bubble circle and text is a different size from the Section callout. Why? See attached image.
Within the Palette you are able to assign a Scale to a Block when right clicking. Are these two both at a Scale of 1?
BTW - These are of different size here too and the Scale is 1 for each. It may be an AIA standard. One of the architects in the Forum will need to answer that.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
