AutoCAD LT Forum
annonative in viewport
2 REPLIES 2
284 Views, 2 Replies
Good afternoon,
I am currently working with annotation scales. Now I walk into a problem:
I have a number of options in dimstyle created this works well. But when I was a dimline add to the drawing later it will not display correctly in the viewport. When I look at the options, I see annotation object scale, not all values ​​are. How can I get there in advance. I has to add scales now.
Paul
2 REPLIES 2
pendean
LT version?
Is your desired DIMSTYLE the current active/set DIMSTYLE?
Does your desired DIMSTYLE have overrides set?
Can you share a DWG with the problem and she is in it how to replicate the problem?
in reply to: pendean
Autocad LT 2015
see the attachment. Herein, I signed two new dimlines. These are not displayed in the correct scale in the viewport. When I go into the viewport zoom out to 1: 100 and then again to 1:20 it's good. However, this is again an additional operation
”Boost
