AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
angle option in LT2013 array command--
1 REPLY 1
ron.white
405 Views, 1 Reply
If you miss the angle option in the array comand in LT2013--tech support sent me this info--
"The angle options is removed from command line
option. However, after creation please hover the bottom right grip and select
Axis Angle and specify the angle by picking a point. If you want to enter angle
value please turn off the dynamic input and enter the angle value in the
command line. "
Tags (1)
1 REPLY 1
pendean
in reply to: ron.white
Thanks for sharing. If you get a chance, tag your own post as the solution here so others can find it.
”Boost
