I seem to have a (new?) icon that I don't recognize. Two overlapping squares apparently whenever I hover over an intersection and I have never seen this before.
Is it part of Quick Properties? I have QPMODE set to 0 (zero) and do not use running OSNAP generally.
Checked HELP file and no joy there but then I am not sure what I am looking for.
Any help here? Enable/Disable? Variable setting somewhere?
TIA
DJ
Solved by pendean. Go to Solution.
SelectionCycling, you turned it on: icon on the bottom of your LT screen looks like your description, except the top square is green, bottom is white and a cursor + sign next to them.
@pendean wrote:SelectionCycling, you turned it on: icon on the bottom of your LT screen looks like your description, except the top square is green, bottom is white and a cursor + sign next to them.
Thanx, Dean, I had a sneaking suspicion that was what it was.
John
