AutoCAD LT General Discussion
Active Member
kenzie1313
Message 1 of 15 (429 Views)
Adding system printer
429 Views, 14 Replies
02-17-2012 02:41 AM
I am using LT 2000i on windows 7, when i use the add a plotter wizard and select a system printer it crashes, can anyone help ???
Charles_Shade
Message 2 of 15 (426 Views)
Re: Adding system printer
02-17-2012 04:28 AM in reply to: kenzie1313
Print and Plot Forum:
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
Leave more info about OS and how the 2000 is installed.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
kenzie1313
Message 3 of 15 (424 Views)
02-17-2012 05:27 AM in reply to: kenzie1313
jpeg of os attached, 2000 installed per manufacturers instructions
Charles_Shade
Message 4 of 15 (420 Views)
02-17-2012 06:03 AM in reply to: kenzie1313
So you installed the LT 2000i seat using XP mode?
And there is no need to run the Wizard.
You can just plot to a Windows system printer/plotter.
Active Member
kenzie1313
Message 5 of 15 (414 Views)
02-17-2012 06:12 AM in reply to: kenzie1313
I loaded the software in normal windows 7 mode, I cant see my network printers when i go to plot, thats why I'm looking to add a printer
Charles_Shade
Message 6 of 15 (411 Views)
02-17-2012 06:30 AM in reply to: kenzie1313
Not sure you have this dialog but:
OPTIONS from the Command line
Plot and Publish tab
about midway down on the right is there Hide System Printers checked?
Active Member
kenzie1313
Message 7 of 15 (409 Views)
02-17-2012 06:48 AM in reply to: kenzie1313
Thanks for the info, I looked in the option window (jpeg attached) the hide system printers box is not enabled,
Charles_Shade
Message 8 of 15 (402 Views)
02-17-2012 07:33 AM in reply to: kenzie1313
Also Service Pack 2 lists a fix to plot crashes in the software.
Do you have this SP2 installed?
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Active Member
kenzie1313
Message 9 of 15 (399 Views)
02-17-2012 07:42 AM in reply to: kenzie1313
My plot window looks like the attached picture, I did try and Load SP1 and 2 as the solution but got an error message (1603) and they wouldnt load.
Charles_Shade
Message 10 of 15 (392 Views)
02-17-2012 08:06 AM in reply to: kenzie1313
Is that the only option you have in the Plotter window? (the dropdown highlighted in blue.)
If you click on the down arrow the Window here does not expand?
If you installed the program in Win 7 and not using a compatibility mode that may be the entire problem and the reason that the Service Packs would not install.
LT 2000i is probably Win95, 98, or 2000 compatible and may need to be run in one of these environments.
Since you have Win 7 Pro you should be able to do this but it may involve removing and reinstalling the LT 2000i
