I have made a button for the following macro to remove the z coordinate from lines and would like to be able to call it from the command line.
Any ideas? Just adding it to the ribbon didn't let me call it from the command line.
Brandon Gingerich
Solved by pendean. Go to Solution.
You can't call a menu macro from the command line: you need full AutoCAD and LISP to do just things.
Nuts
Thanks for your answer.
Brandon Gingerich
